You can move a focused panel object to a different location on a panel or drawer, or you can move the object to the next panel. To move a panel object, perform the following steps:
Press Tab to give focus to the object.
Press Shift+F10 to open the panel object popup menu.
Use the arrow keys to select the Move menu item.
Use the keyboard shortcuts that are listed in the following table to perform the move operation.
Keys |
Function |
arrow keys |
Move the object left and right on a horizontal panel or up and down on a vertical panel. |
Shift + arrow keys |
Move the object and push any objects that you encounter in front of the object. |
Ctrl + arrow keys |
Move the object and swap position with any objects that you encounter in the move. |
Tab |
Move the object to the next panel. |
spacebar |
Complete the move operation. |
The following examples demonstrate the effect of different move operations on the objects in a panel.
Illustration |
Description |
Shows a panel with three panel objects before a move operation takes place. |
Shows the effect
of using the arrow keys to move the |
Shows the effect
of using the Shift + arrow keys to move the |
Shows the effect
of using the Ctrl + arrow keys to move the |
