The following table lists the keyboard shortcuts that you can use to navigate menus on panels.
Keys |
Function |
spacebar |
Open the menu that has focus. |
arrow keys |
Navigate the menu. |
spacebar |
Select a menu item. |
Shift + F10 |
Open the popup menu associated with a menu item, if one exists. |
Esc |
Close a menu. |
