The following sections describe how to navigate and use standard user interface elements and controls from the keyboard.
The following table lists the keyboard shortcuts that you can use to navigate menus.
Keys |
Function |
up arrow and down arrow |
Give focus to the next or previous menu item on a menu. |
right arrow |
If the menu item that has focus is a submenu, open the submenu and give focus to the first menu item on the submenu. If the menu item that has focus is not a submenu, open the next menu on the menubar. |
left arrow |
If the menu item that has focus is a submenu item, switch the focus back to the submenu. If the menu item that has focus is not a submenu item, open the previous menu on the menubar. |
Return |
Select the focused menu item and close the open menus. |
access key |
Select the menu item that is associated with the access key and close the open menus. |
spacebar |
Select the focused menu item and close the open menus except when the menu item is a check box or radio button. If the menu item is a check box or radio button, the menu does not close. |
Esc |
Close the open menus. |
A button is a control that you use to start an action. Most buttons are rectangular and contain a text label.
The following table lists the keyboard shortcuts that you can use to navigate buttons.
Keys |
Function |
spacebar |
Activate the button that has focus. This is the equivalent of clicking on the button. |
Return |
Activate the button that has focus or, if no button has focus, perform the default action for the dialog. |
A radio button is a control that you use to select one of several mutually-exclusive options.
The following table lists the keyboard shortcuts that you can use to navigate a set of radio buttons.
Keys |
Function |
arrow keys |
Select the next or previous radio button and deselect the other radio buttons in the group. |
A check box is a control that you use to select or deselect an option.
The following table lists the keyboard shortcuts that you can use to navigate a check box.
Keys |
Function |
spacebar |
Select or deselect the check box. |
Text boxes are controls in which you type text.
The following table lists the keyboard shortcuts that you can use to navigate a single line text box.
Keys |
Function |
left arrow |
Position the cursor one character to the left. |
right arrow |
Position the cursor one character to the right. |
Ctrl + left arrow |
Position the cursor at the start of the current word. Press-and-hold Ctrl and continue to press left arrow to position the cursor at the start of the previous word. |
Ctrl + right arrow |
Position the cursor at the end of the current word. Press-and-hold Ctrl and continue to press right arrow to position the cursor at the end of the next word. |
Home |
Position the cursor at the start of the line. |
End |
Position the cursor at the end of the line. |
Shift + left arrow or right arrow |
Select one character at a time to the left or right of the cursor. |
Shift + Ctrl + left arrow or right arrow |
Select one word at a time to the left or right of the cursor. |
Shift + Home |
Select all text to the left of the cursor. |
Shift + End |
Select all text to the right of the cursor. |
Ctrl + A (Solaris only) |
Select all text in the text box. |
In addition to the keyboard shortcuts listed in the previous table, use the keyboard shortcuts in the following table to navigate multi-line text boxes.
Keys |
Function |
Page Up |
Position the cursor at the top of the current view. Press Page Up again to position the cursor at the top of the previous view. |
Page Down |
Position the cursor at the end of the current view. Press Page Down again to position the cursor at the end of the previous view. |
Ctrl + up arrow |
Position the cursor at the start of the current paragraph. Press-and-hold Ctrl and continue to press the up arrow key to position the cursor at the start of the previous paragraph. |
Ctrl + down arrow |
Position the cursor at the end of the current paragraph. Press-and-hold Ctrl and continue to press the down arrow key to position the cursor at the end of the next paragraph. |
Ctrl + Page Up |
Position the cursor one view width to the left. |
Ctrl + Page Down |
Position the cursor one view width to the right. |
Ctrl + Home |
Position the cursor at the start of the text box. |
Ctrl + End |
Position the cursor at the end of the text box. |
Ctrl + Tab |
Give focus to the next control on the dialog. |
Shift + Page Up |
Select the text to the start of the current view. Press-and-hold Shift and continue to press Page Up to extend the selection to the start of the previous view. |
Shift + Page Down |
Select the text to the end of the current view. Press-and-hold Shift and continue to press Page Down to extend the selection to the end of the next view. |
Shift + Home |
Select the text to the start of the line. |
Shift + End |
Select the text to the end of the line. |
Shift + Ctrl + up arrow |
Select the text to the start of the paragraph, then to the start of the previous paragraph. |
Shift + Ctrl + down arrow |
Select the text to the end of the paragraph, then to the end of the next paragraph. |
Shift + Ctrl + Home |
Select the text to the start of the text box. |
Shift + Ctrl + End |
Select the text to the end of the text box. |
A spin box is a control that allows you to type a numeric value or select a value from a list of all possible values.
The keyboard shortcuts that you use to navigate the text box area of a spin box are listed in 3.9.5 To Navigate Text Boxes. The following table lists the keyboard shortcuts that you can use to navigate the up and down arrows in the spin box.
Keys |
Function |
up arrow or down arrow |
Increase or decrease the value of the spin box by a small amount. |
Page Up or Page Down |
Increase or decrease the value of the spin box by a large amount. |
A drop-down list is a control that you use to select one of several available items. The drop-down list contains a button that you use to display the available items.
The following table lists the keyboard shortcuts that you can use to navigate a drop-down list.
A drop-down combination box is a text box with a drop-down list attached.
When the text box has focus, use the keyboard shortcuts that are listed in 3.9.5 To Navigate Text Boxes to navigate the text box area. When the text box has focus, you can also use the keyboard shortcuts in the following table to navigate the drop-down list area.
Keys |
Function |
up arrow |
Select the previous item from the drop-down list without displaying the list. |
down arrow |
Select the next item from the drop-down list without displaying the list. |
Ctrl + down arrow (Solaris only) |
Open the drop-down list. |
When the drop-down list has focus, you can use the keyboard shortcuts that are listed in the following table to navigate the drop-down list.
Keys |
Function |
up arrow |
Select the previous list item. |
down arrow |
Select the next list item. |
Home |
Select the first item on the list. |
End |
Select the last item on the list. |
Page Up |
Select the item at the top of the current list view. |
Page Down |
Select the item at the bottom of the current list view. |
spacebar |
Accept the current selection and close the drop-down list. |
Ctrl + Page Up |
Scroll to the left of the list, if required. |
Ctrl + Page Down |
Scroll to the right of the list, if required. |
A slider is a control that you use to set a value in a continuous range of values.
The following table describes the keyboard shortcuts that you can use to navigate a slider.
Keys |
Function |
left arrow or up arrow |
Move the slider left or up by a small amount. |
right arrow or down arrow |
Move the slider right or down by a small amount. |
Page Up |
Move the slider left or up a large amount. |
Page Down |
Move the slider right or down a small amount. |
Home |
Move the slider to the maximum value. |
End |
Move the slider to the minimum value. |
Windows and dialogs are sometimes divided into logical sections that are displayed one section at a time on the window or dialog. The divisions are called tabbed sections that are identified by a tab with a text label.
The following table lists the keyboard shortcuts that you can use to navigate the tabbed sections of a window or dialog when a tab name has focus.
Keys |
Function |
left arrow |
Give focus to the previous tabbed section. |
right arrow |
Give focus to the next tabbed section. |
Tab orCtrl + down arrow |
Give focus to the first control on the active tabbed section. |
The following table lists the keyboard shortcuts that you can use to navigate the tabbed sections of a window or dialog when a control on a tabbed section has focus.
Keys |
Function |
Ctrl + Page Up or Ctrl + Alt + Page Up |
Give focus to the previous tabbed section. This keyboard shortcut does not work if the focused control uses Ctrl+ Page Up for another purpose. |
Ctrl + Page Down or Ctrl + Alt + Page Down |
Give focus to the next tabbed section. This keyboard shortcut does not work if the focused control uses Ctrl+ Page Down for another purpose. |
Ctrl + Tab |
Give focus to the next control outside the tabbed sections. |
The following table lists the keyboard shortcuts that you can use to navigate multi-column lists when a column header has focus.
Keys |
Function |
Give focus to the previous or next column header. |
spacebar |
Activate the header. This action usually sorts the list by the column header. |
Tab |
Give focus to the list contents. |
The following table lists the keyboard shortcuts that you can use to navigate lists when the contents of the list has focus.
Keys |
Function |
arrow keys |
Select the next or previous row or column. |
Page Up |
Select the top row of the list contents that are in view. Press Page Up again to select the top row of the previous view. |
Page Down |
Select the bottom row of the list contents that are in view. Press Page Down again to select the bottom row of the next view. |
Home |
Select the first row in the list. |
End |
Select the last row in the list. |
Shift + arrow keys |
For lists that support multi-line selections, add the next or previous row or column to the current selection. For lists that only allow single line selections, select the next or previous row or column. |
Shift + Page Up |
Select all the rows between the current selection and the top row of the view. |
Shift + Page Down |
Select all the rows between the current selection and the bottom row of the view. |
Shift + Home |
Select all the rows between the current selection and the first row in the list. |
Shift + End |
Select all the rows between the current selection and the last row in the list. |
Ctrl + arrow keys |
Give focus to the next row or column but do not extend the selection. |
Ctrl + Page Up |
Give focus to the top row in the view but do not extend the selection. |
Ctrl + Page Down |
Give focus to the bottom row in the view but do not extend the selection. |
Ctrl + Home |
Give focus to the first row in the list but do not extend the selection. |
Ctrl + End |
Give focus to the last row in the list but do not extend the selection. |
Return |
Activate the item. |
Ctrl + A |
For lists that support multiline selections, select all rows in the list. |
Shift + Tab |
Give focus to the column header, if applicable. |
A tree is a user interface control that contains sections that you can expand and collapse. A tree usually represents a hierarchical structure.
To navigate trees, you can use the same keyboard shortcuts that are listed in 3.9.11 To Navigate Lists. In addition, the following table lists the keyboard shortcuts you can use for the tree items.
Keys |
Function |
+ (plus) |
Expand the focused item. |
- (minus) |
Collapse the focused item. |
Back Space |
Select the parent item. |
Ctrl + F |
Display a search dialog. You can type the name of the tree item that you want to find. |
