Email Functions
Table C–1 lists the keyboard shortcuts that you
can use to perform general email functions.
Table C–1 Keys for General Email Functions
Keys
Function
Tab
Move focus between the following interface items, in the following order:
Folder pane
The elements in the searchbar
Message list
If the preview pane is displayed, the active elements in the
selected message, such as the To and From
email addresses.
Shift + Tab
Move focus between the interface items listed for
the Tab key, in reverse order.
Table C–2 lists the keyboard shortcuts that
you can use to perform message list functions.
Table C–2 Keys for Message List Functions
Keys
Function
Page Up
Select the message at the top of the list.
Page Down
Select the message at the bottom of the list.
up arrow, down arrow
Select the previous or next message.
Table C–3 lists the keyboard shortcuts that you
can use to perform message functions in a message window, or in the preview
pane.
Table C–3 Keys for Message Functions
Keys
Function
Tab
Move focus between the active elements in the message from the top to the
bottom. Active elements include the following:
To and From email
addresses.
HTML elements.
Buttons that represent attachments.
If an attachment is displayed within the message, active
elements within the attachment.
Shift + Tab
Move focus between the elements listed for the Tab key, in reverse order.
Return
Perform the default action on
the element that has focus. For example, if the right side of an attachment
button is selected, press Return to open a popup menu that
enables you to perform actions on the attachment.
Ctrl + Tab
When you view a message in the preview pane, move
the focus to the folder pane.
Ctrl + Shift + Tab
When you view a message in the preview pane, move the focus to the message
list.
F7
Turns caret mode on and off.
Caret mode enables you to use the keyboard to select text when you view a
message.
