Use the Color tabbed section to set color preferences for labels.
To change the color of a label, click on the color selector button at the right side of the label text box. Use the Pick a color dialog to select the color that you require for the label.
To create a new label, you must overwrite one of the current labels. Type a name for the new label in the text box of the label that you want to overwrite. To change the color of the label, click on the color selector button at the right side of the text box. Use the Pick a color dialog to select the color that you require for the label.
To restore the Email and Calendar default
settings for labels, click on the Restore defaults
button.
