Use the Signatures tabbed section to set signature preferences. Table 12–9 lists the signature preferences that you can set.
Table 12–9 Signature Preferences|
Dialog Element |
Description |
Signature list |
Displays a list of signatures that you can insert into your messages. When you compose a message, you can select one of the signatures from the Signature drop-down list. |
Add |
Click on this button to add a signature to the list of signatures. To add a signature to the list of signatures, perform the following steps:
Add Script |
You can use a script to generate your signature. Click on the Add Script button to add a script to generate your signatures. To add a script to the list of signatures, perform the following steps:
Edit |
To edit a signature or a signature script, select the item from the signature list, then click on the Edit button. |
Remove |
To delete a signature or a signature script, select the item from the signature list, then click on the Remove button. |
