To configure your mail accounts, click on the Mail Accounts icon in the left pane of the Settings dialog. Table 12–1 lists the dialog elements that you can use to configure your mail account settings.
Table 12–1 Mail Account Preferences|
Dialog Element |
Description |
Accounts table |
This table lists your mail accounts. Double-click on a mail account to edit the mail account. |
Add |
Click on this button to add a mail account. The For more information about how to add a mail account, see Using the Setup Assistant. |
Edit |
To edit a mail account, select the account in the accounts table, then click on the Edit button. For more information about how to edit a mail account, see To Edit a Mail Account. |
Remove |
To delete a mail account, select the account in the accounts table, then click on the Remove button. A confirmation dialog is displayed. Click Delete on the confirmation dialog to delete the mail account. |
Default |
To make a mail account your default mail account, select the account in the accounts table, then click on the Default button. |
Enable, Disable |
To disable a mail account, select the account in the accounts table, then click on the Disable button. Alternatively, click on the check box in the Enabled column for the account. To enable a mail account, select the account, then click on the Enable button. Alternatively, click on the check box in the Enabled column for the account. |
You can customize your mail account in the following functional areas:
Identity
Receiving Mail
Receiving Options
Sending Mail
Defaults
Security
Use the Identity tabbed section to specify identity details for a mail account. For information about the elements in the Identity tabbed section, see Configuring Account Management Settings and Entering Your Identity Information. Table 12–2 lists the identity details that you can specify that are not described in those sections.
Table 12–2 Mail Account Identity Preferences|
Dialog Element |
Description |
Default signature |
Select a signature to use as your default signature from the drop-down list. The signature that you select is added to all your messages. |
Add new signature |
Click on this button to add a signature to the list of signatures. To add a signature to the list of signatures, perform the following steps:
Use the Receiving Mail tabbed section to specify details for receiving mail for a mail account. For information about the elements in the Receiving Mail tabbed section, see Configuring a Mail Server From Which to Receive Email.
Use the Receiving Options tabbed section to specify options for receiving mail for a mail account. For information about the elements in the Receiving Options tabbed section, see Configuring How to Receive Email.
Use the Sending Mail tabbed section to specify details for sending mail from a mail account. For information about the elements in the Sending Mail tabbed section, see Configuring How to Send Email.
Use the Defaults tabbed section to specify default preferences for a mail account. Table 12–3 lists the default preferences that you can specify.
Table 12–3 Mail Account Default Preferences|
Dialog Element |
Description |
Drafts folder |
When you choose File -> Save Draft from the Compose a message window, the draft message is saved. Use this preference to specify the folder in which to store your draft messages. Click on the folder button to open the Select Folder dialog. Select the folder in which to store your draft messages from the Select Folder dialog, then click OK. |
Sent messages folder |
When you send a message, a copy of the message is saved automatically. Use this preference to specify the folder in which to store your sent messages. Click on the folder button to open the Select Folder dialog. Select the folder in which to store your sent messages from the Select Folder dialog, then click OK. |
Restore Defaults |
Click on this button to restore the |
Always carbon-copy (Cc) to |
Select this option if you want to copy all of your messages to an address. Enter the address to which you want to copy your messages in the field. If you want to copy your messages to more than one address, separate the addresses with a comma. |
Always blind carbon-copy (Bcc) to |
Select this option if you want to blind-copy all of your messages to an address. Enter the address to which you want to blind-copy your messages in the field. If you want to blind-copy your messages to more than one address, separate the addresses with a comma. |
Use the Security tabbed section to specify your PGP or GPG security preferences for a mail account. PGP and GPG are applications that are used to encrypt and decrypt messages.
Table 12–4 lists the security preferences that you can set.
Table 12–4 Mail Account Security Preferences|
Dialog Element |
Description |
PGP/GPG Key ID |
Type your public key in the text box. |
Always sign outgoing messages when using this account |
Select this option to attach an encrypted signature to all messages that you send from this email account. |
Don't sign meeting requests (for Outlook compatibility) |
Select this option if you do not want to attach an encrypted signature when you send meeting information to attendees in Calendar.
Always encrypt to myself when sending encrypted mail |
Select this option to always send a copy of your encrypted messages to yourself in encrypted form. Select this option if you want to be able to decrypt the encrypted messages that you send, for example, in your Sent folder or Outbox folder. |
Always trust keys in my keyring when encrypting |
Select this option if you do not want to validate the public keys of contacts who are in your public keyring when you encrypt a message. A public keyring is a file that lists all of the public keys that you know. |
