Java Desktop System Email and Calendar User Guide
To Save Contacts in Vcard Format
Perform the following steps:
  1. In a contacts folder, select the contact or contact list that you want to save, then choose File -> Save as VCard.
    Alternatively, select the contact or contact list, then right-click on the contact or contact list. Choose Save as VCard from the popup menu.
  2. Use the Save as VCard dialog to specify a location and name for the file.
