Java Desktop System Email and Calendar User Guide
To Copy Contacts
To copy a contact or contact list to another folder, perform the following steps:
  1. In a contacts folder, select the contact or contact list that you want to copy, then choose Actions -> Copy to Folder.
    Alternatively, select the contact or contact list, then right-click on the contact or contact list. Choose Copy to folder from the popup menu.
  2. Use the Copy card to dialog to specify the folder to which you want to copy the contact or contact list.
Note –
You can only copy a contact or contact list to folders whose folder type is Contacts.
