Perform the following steps:
In a contacts folder, select the contact that you want to edit, then choose File -> Open. Alternatively, double-click on the contact.
A Contact Editor dialog is displayed with the details of the contact.
Use the Contact Editor dialog to modify the information for the contact. For information about the elements in the Contact Editor dialog, see To Add a Contact.
Choose File -> Save to save your changes.
