Email and Calendar
enables you to search
your contacts. You can use the searchbar to perform a simple search of all
contacts in a folder. For example, you can search for a message that contains
a particular text string. You can use the alphabetic index buttons to search
for a contact whose name begins with a particular letter.
You can also perform advanced searches that use more complex search criteria. For example, you can search for contacts by email address or category.
Perform the following steps:
Display the folder that contains the contacts that you want to search.
Select the contact component in which to search from the drop-down list in the searchbar.
Type the text that you want to search for in the text box on the searchbar.
Click on the Find Now button. Alternatively, choose Search -> Find Now. The contacts that match the search criteria are displayed.
To clear the search criteria and display all the contacts in the folder, choose Search -> Clear. Alternatively, click on the Clear button in the searchbar.
You can also use the alphabetic index buttons at the right side of the window to search for contacts. To search for a contact whose name begins with a particular letter, click on that letter. To search for contacts whose name begins with a number or another non-alphabetic character, click on the 123 index button.
Choose Tools -> Search for Contacts. Alternatively, select Advanced from the drop-down list in the searchbar. An Advanced Search dialog is displayed.
Use the If group box to create criteria for the search. To create criteria, perform the following steps:
From the first drop-down list, select the contact component in which to search. For example, select Email to search the text in the email address of the contact.
From the second drop-down list, select the relationship between the contact component and the search text. For example, to search for contacts whose email address includes the search text, select contains from the second drop-down list.
In the text box, type the search text. This text is not case sensitive.
To add more criteria, click on the Add button. To remove a criterion, click on the Remove button beside the criterion.
Select the appropriate option from the Execute actions drop-down list. Select one of the following options:
if any criteria are met: Select this option if you want the search to return matches where any of the specified criteria are met.
if all criteria are met: Select this option if you want the search to return only matches where all of the specified criteria are met.
Click OK to perform the advanced search. The contacts that match are displayed in the contacts folder.
To clear the advanced search criteria and display all the messages in the folder, choose Search -> Clear.
