Java Desktop System Email and Calendar User Guide
Working With Shortcuts
You can add, rename, and remove shortcuts from your shortcuts groups. The following sections describe how to work with shortcuts.
To Add a Shortcut
To add a shortcut to a shortcuts group, perform the following steps:
  1. Open the shortcuts group to which you want to add the shortcut.
  2. In the folder pane, select the folder for which you want to add a shortcut, then choose File -> Folder -> Add to Shortcut Bar. The folder is added to the shortcuts group as a shortcut.
To Add Default Shortcuts
You can add the default shortcuts to a shortcuts group. To add the default shortcuts to a shortcuts group, perform the following steps:
  1. Open the shortcuts group to which you want to add the default shortcuts.
  2. Right-click on a vacant space on the shortcuts bar, then choose Create Default Shortcuts from the popup menu. The default shortcuts are added to the shortcuts group.
To Rename a Shortcut
Right-click on the shortcut, then choose Rename from the popup menu. A Rename Shortcut dialog is displayed. Type a new name for the shortcut in the dialog, then click OK. The text on the shortcut is updated.
To Remove a Shortcut
Right-click on the shortcut, then choose Remove from the popup menu.
