Java Desktop System Email and Calendar User Guide
To Grant Access Permissions to a User
Perform the following steps:
  1. Right-click on the folder and choose Permissions from the popup menu to display the Folder permissions dialog.
  2. Click Add to display the Add permission dialog.
  3. Type the name of the user in the User text box.
  4. Select some or all of the required permissions:
    • Availability
    • Invite
    • Read
    • Delete
    • Modify
  5. Click OK to save your changes and close the Add permission dialog.
  6. Click OK to save your changes and close the Folder permissions dialog.
