3.4 Gestures for Starting Accessibility Applications Do Not Work
Platform
Solaris
Problem
Change Request Number:
6214222
The GNOME Display Manager (GDM) gestures for starting
the assistive technologies such as On-Screen Keyboard
and Screen Reader and Magnifier do not work.
Solution
Use the full path to
the applications in the GDM configuration files.
Perform the following
steps:
Edit the following two files:
/etc/X11/gdm/modules/AccessKeyMouseEvents
/etc/X11/gdm/modules/AccessDwellMouseEvents
Replace all occurrences of gok with /usr/sfw/bin/gok.
Replace all occurrences of srcore with /usr/sfw/bin/srcore.
