Solution
To set either virtual
or real dual-head magnification in the Screen Reader and Magnifier application, you must perform the following steps:
Open the Zoomer Options dialog.
Type the value you require in the Source
field, then press Return.
Type the value you require in the Target
Note –
The changes to the Source and Target fields do not take effect until you press Return.
