Disable wire frame
mode in Window Manager.
Perform the following steps:
Click Launch, then choose Applications -> Utilities -> Configuration Editor.
In GConf editor, choose Apps -> Metacity -> General.
Ensure that the reduced_resources key
is not selected.
Alternatively, you can enter the following command from
a terminal window:
gconftool-2 -t bool -s /apps/metacity/general/reduced_resources
false
