This chapter describes workarounds for known accessibility issues in the Java Desktop System Release 3.
Platform |
Solaris |
Problem |
If an application crashes, the application can continue to run but CORBA traffic to and from the application stops. This situation might prevent accessibility information from passing between other applications and the accessibility applications. |
Solution |
To resolve the situation, set the following environment variable value to 1: GNOME_DISABLE_CRASH_DIALOG |
Platform |
Linux |
Problem |
Change Request Number: 6291788 The Java Desktop System Release 3 Accessibility Guide contains an incorrect instruction in the section entitled "To Configure GDM on Linux Systems". |
Solution |
In the section entitled "To Configure GDM on Linux Systems", step 4 should read as follows: Search the file for the following line: #GtkModulesList=gail:atk-bridge:/usr/lib/gtk-2.0 /modules/libdwellmouselistener:/usr/lib/gtk-2.0 /modules/libkeymouselistener and delete the # from the start of the line so that the line reads: GtkModulesList=gail:atk-bridge:/usr/lib/gtk-2.0 /modules/libdwellmouselistener:/usr/lib/gtk-2.0 /modules/libkeymouselistener |
Platform |
Solaris |
Problem |
Change Request Number: 6205225 On a system with two framebuffers configured, full screen magnification does not work. |
Solution |
Please contact the Customer Resolution Center to obtain a patch for this issue. |
Platform |
Solaris |
Problem |
Change Request Number: 6202413 Java applications are not displayed correctly in the magnifier. The entire Java window might initially be blank in the magnified area. |
Solution |
Set the following environment variable: NO_J2D_DGA=true |
Platform |
Solaris and Linux |
Problem |
Change Request Number: 5085440 When you use the |
Solution |
Move the cursor into the hyperlink. On Linux systems, use flat review mode instead of caret navigation mode to navigate the message. |
Platform |
Solaris and Linux |
Problem |
Change Request Number: 6216962 You are unable to navigate or receive speech output for HTML containers such as web pages, email messages, or Help content. |
Solution |
Press F7
to enable caret navigation mode. Refer to the Java Desktop System
Release 3 Accessibility Guide for more information about how to
use the caret navigation mode. You can also refer to the online Help for the |
