Solution
Perform the following
steps:
Click Launch, then choose Applications -> Utilities -> Configuration Editor
In GConf, choose Apps -> Nautilus -> Desktop.
Select the primary_screen key and set
the value to the value of the magnified screen. For example, if the target
screen for magnification is 1, set the value to 1.
Alternatively, you can enter the following command from
a terminal window:
gconftool-2 --type integer --set
/apps/nautilus/desktop/primary_screen 1
