Java Desktop System Release 3 Accessibility Release Notes
Typographic Conventions
The following table describes the typographic changes that are used in this book.
Table P–2 Typographic Conventions
Typeface or Symbol
Meaning
Example
AaBbCc123
 The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
 What you type, contrasted with onscreen computer output
machine_name% su
Password:
AaBbCc123
 Command-line placeholder: replace with a real name or value
The command to remove a file is rm filename.
AaBbCc123
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
These are called class options.
Do not save the file.
(Emphasis sometimes appears in bold online.)
