NAME | Synopsis | Interface Level | Description | Return Values | Attributes | See Also | Notes
cc [flag...] file... -ltsol [library...]
#include <tsol/label.h> int htobsl(const char *s, m_label_t *label);
int htobclear(const char *s, m_label_t *clearance);
The htobsl() and htobclear() functions are obsolete. Use the str_to_label(3TSOL) function instead.
These functions convert hexadecimal string representations of internal label values into binary labels.
htobsl() converts into a binary sensitivity label, a hexadecimal string of the form:
0xsensitivity_label_hexadecimal_value |
htobclear() converts into a binary clearance, a hexadecimal string of the form:
0xclearance_hexadecimal_value |
These functions return non-zero if the conversion was successful, otherwise zero is returned.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWtsu |
Stability Level |
Obsolete |
MT-Level |
MT-Safe |
These functions are obsolete and retained for ease of porting. They might be removed in a future Solaris Trusted Extensions release.
