NAME | Synopsis | Description | Options | Examples | Exit Status | Files | Attributes | See Also
/usr/sadm/bin/smtnrhdb subcommand [auth_args] -- subcommand_args]
The smtnrhdb command adds, modifies, deletes, and lists entries in the tnrhdb database.
smtnrhdb subcommands are:
Adds a new entry to the tnrhdb database. To add an entry, the administrator must have the solaris.network.host.write and solaris.network.security.write authorizations.
Deletes an entry from the tnrhdb database. To delete an entry, the administrator must have the solaris.network.host.write and solaris.network.security.write authorizations.
Lists all entries in the tnrhdb database. To list an entry, the administrator must have the solaris.network.host.read and solaris.network.security.read authorizations.
Modifies an entry in the tnrhdb database. To modify an entry, the administrator must have the solaris.network.host.write and solaris.network.security.write authorizations.
The smtnrhdb authentication arguments, auth_args, are derived from the smc arg set. These arguments are the same regardless of which subcommand you use. The smtnrhdb command requires the Solaris Management Console to be initialized for the command to succeed (see smc(1M)). After rebooting the Solaris Management Console server, the first smc connection can time out, so you might need to retry the command.
The subcommand-specific options, subcommand_args, must be preceded by the -- option.
The valid auth_args are -D, -H, -l, -p, -r, and -u; they are all optional. If no auth_args are specified, certain defaults will be assumed and the user might be prompted for additional information, such as a password for authentication purposes. These letter options can also be specified by their equivalent option words preceded by a double dash. For example, you can use either -D or --domain.
Specifies the default domain that you want to manage. The syntax of domain=type:/host_name/domain_name, where type is dns, ldap, or file; host_name is the name of the server; and domain_name is the name of the domain you want to manage.
If you do not specify this option, the Solaris Management Console assumes the file default domain on whatever server you choose to manage, meaning that changes are local to the server. Toolboxes can change the domain on a tool-by-tool basis; this option specifies the domain for all other tools.
Specifies the host_name and port to which you want to connect. If you do not specify a port, the system connects to the default port, 898. If you do not specify host_name:port, the Solaris Management Console connects to the local host on port 898.
Specifies the password for the role_name. If you specify a role_name but do not specify a role_password, the system prompts you to supply a role_password. Passwords specified on the command line can be seen by any user on the system, hence this option is considered insecure.
Specifies the password for the user_name. If you do not specify a password, the system prompts you for one. Passwords specified on the command line can be seen by any user on the system, hence this option is considered insecure.
Specifies a role name for authentication. If you do not specify this option, no role is assumed.
Specifies the user name for authentication. If you do not specify this option, the user identity running the console process is assumed.
This option is required and must always follow the preceding options. If you do not enter the preceding options, you must still enter the -- option.
Note: Descriptions and other arg options that contain white spaces must be enclosed in double quotes.
Displays the command's usage statement.
Specifies the name of the host. For the list subcommand, the hostname argument is not specified. This is not required if the ipaddress subcommand argument is specified.
Specifies the IP address of the host. This is not required if the hostname subcommand argument is specified.
Specifies the name of the template.
Specifies the prefix length (in bits) of a wildcard representation of the IP address. The prefix is the left-most portion of the IP address.
Specifies the IP address of the subnet using a wildcard.
One of the following sets of arguments must be specified for subcommand add:
-H hostname -n templatename | -i ipaddress -n templatename | -w ipaddress-wildcard -n templatename [ -p prefixlen ] | -h |
One of the following sets of arguments must be specified for subcommand modify:
One of the following sets of arguments must be specified for subcommand delete:
-H hostname | -i ipaddress | -w ipaddress-wildcard [ -p prefixlen ] | -h |
The subcommand list takes the following argument:
-h |
The admin role specifies the template name, cipso_lan, for a series of hosts that use the IP address wildcard 192.168.113.0 on the local file system. Since no authorization arguments were specified, the administrator connects to port 898 of the local host on the local server with the file domain type, which are the defaults. The administrator is prompted for the admin password.
$ usr/sadm/bin/smtnrhdb add -- -w 192.168.113.0 -n cipso_lan |
The admin role connects to port 898 (which happens to be the default) of the LDAP server and deletes a host entry from the database by specifying its IP address, 192.168.113.8. Since the domain was not specified, the file domain type and local server are used by default. The administrator is prompted for the admin password.
/usr/sadm/bin/smtnrhdb delete \ -D ldap:/example.domain -i 192.168.113.8 |
The following exit values are returned:
Successful completion.
Invalid command syntax. A usage message displays.
An error occurred while executing the command. An error message displays.
The following files are used by the smtnrhdb command:
Trusted network remote-host database. See tnrhdb(4).
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWmgts |
