NAME | Synopsis | Description | Parameters | Attributes | Return Values | Errors | See Also
#include <X11/extensions/Xtsol.h> Status XTSOLgetPropLabel(display, window, property, sl); Display *display; Window window; Atom property; m_label_t *sl;
Client requires the PRIV_WIN_DAC_READ and PRIV_WIN_MAC_READ privileges. XTSOLgetPropLabel() is used to get the sensitivity label that is associated with a property hanging on a window.
Specifies a pointer to the Display structure; returned from XOpenDisplay().
Specifies the ID of the window whose property's label you want to get.
Specifies the property atom.
Returns a sensitivity label that is the current label of the specified property.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWxwts |
MT-Level |
MT-Unsafe |
None
XTSOLgetPropAttributes(3XTSOL), XTSOLsetPropLabel(3XTSOL)
Setting Window Polyinstantiation Information in Solaris Trusted Extensions Developer’s Guide
