NAME | Synopsis | Description | Parameters | Attributes | Return Values | Errors | See Also
#include <X11/extensions/Xtsol.h> Status XTSOLgetResLabel(display, object, type, sl); Display *display; XID object; ResourceType type; m_label_t *sl;
The client requires the PRIV_WIN_DAC_READ and PRIV_WIN_MAC_READ privileges. XTSOLgetResLabel() is used to get the label that is associated with a window or a pixmap or a colormap.
Specifies a pointer to the Display structure; returned from XOpenDisplay().
Specifies the ID of a window system object whose label you want to get. Possible window system objects are windows, pixmaps, and colormaps.
Specifies what type of resource is being accessed. Possible values are IsWindow, IsPixmap or IsColormap.
Returns a sensitivity label which is the current label of the specified object.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWxwts |
MT-Level |
MT-Unsafe |
None
XTSOLgetClientAttributes(3XTSOL), XTSOLsetResLabel(3XTSOL)
Obtaining a Window Label in Solaris Trusted Extensions Developer’s Guide
