NAME | Synopsis | Description | Parameters | Attributes | Return Values | Errors | See Also
#include <X11/extensions/Xtsol.h> Status XTSOLgetResUID(display, object, type, uidp); Display *display; XID object; ResourceType type; uid_t *uidp;
The client requires the PRIV_WIN_DAC_READ and PRIV_WIN_MAC_READ privileges.
XTSOLgetResUID() gets the ownership of a window system object. This allows a client to get the ownership of an object that the client did not create.
Specifies a pointer to the Display structure; returned from XOpenDisplay().
Specifies the ID of a window system object whose UID you want to get. Possible window system objects are windows or pixmaps.
Specifies what type of resource is being accessed. Possible values are IsWindow and IsPixmap.
Returns a UID which is the current UID of the specified object. Client must provide a pointer to uid_t.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWxwts |
MT-Level |
MT-Unsafe |
None
Lack of privilege
Not a valid window
Not a valid pixmap
Not a valid type
XTSOLgetClientAttributes(3XTSOL), XTSOLgetResAttributes(3XTSOL), XTSOLgetResLabel(3XTSOL)
Obtaining the Window User ID in Solaris Trusted Extensions Developer’s Guide
