Description: This problem is specific to systems that use an ATI ES1000 video controller. Although the graphical login screen is visible on the server console, if you attempt to access the server through the remote control function of the Management Module (MM), the graphical login screen is not visible.
The following message is displayed:
No video available
Workaround: Download and install the latest revision of patch 125720 or install at least the Solaris 10 8/07 OS..
