Solaris 10 6/06 Installation Guide: Basic Installations
ProcedureSPARC: To Install or Upgrade With the Solaris Installation Program
This procedure describes how to install a standalone SPARC based system from CD or DVD media.
Note –
If you want to install the Solaris OS on a machine or domain that does not have a directly attached DVD-ROM or CD-ROM drive, you can use a DVD-ROM or CD-ROM drive that is attached to another machine. For detailed instructions, refer to Appendix B, Installing or Upgrading Remotely (Tasks), in Solaris 10 6/06 Installation Guide: Network-Based Installations.
Before You Begin
Perform the following tasks before you begin your installation.
Steps
  1. Insert the Solaris 10 Operating System for SPARC Platforms DVD or Solaris 10 Software for SPARC Platforms - 1 CD.
  2. Boot the system.
    • If the system is new, out-of-the-box, turn on the system.
    • If you want to install a system that is currently running, shut down the system.
    The ok prompt is displayed.
  3. Start the Solaris installation program.
    • To boot from the local DVD or CD and start the Solaris installation GUI, type the following command.
      ok boot cdrom
    • To boot from the local DVD or CD and start the text installer in a desktop session, type the following command.
      ok boot cdrom - text
      text
      Specifies to run the text installer in a desktop session. Use this option to override the default GUI installer.
    • To boot from the local DVD or CD and start the text installer in a console session, type the following command.
      ok boot cdrom - nowin
      nowin
      Specifies to run the text installer in a console session. Use this option to override the default GUI installer.
    For detailed information about the Solaris installation GUI and text installer, see Solaris Installation Program GUI or Text Installer Requirements.
    The installation begins. The installation program prompts you to select a language to use during the installation.
  4. Select the language you want to use during the installation, and press Enter.
    After a few seconds, the Solaris Installation Program Welcome screen appears.
    • If you are running the Solaris GUI installation program, the screen that is shown in Figure 2–1 is displayed.
    • If you are running the Solaris text installer in a desktop session, the screen that is shown in Figure 2–2 is displayed.
    Figure 2–1 Solaris GUI Installation Program Welcome Screen
    This screen capture shows the GUI Welcome screen. This
screen lists the information the installation program needs to configure the
system.
    Figure 2–2 Solaris Text Installer Welcome Screen
    This screen capture shows the text Welcome screen. This
system.
  5. Click Next to begin the installation. If you are prompted, answer the system configuration questions.
    After you answer the configuration questions, the Welcome to Solaris dialog box appears.
    Figure 2–3 Welcome to Solaris Screen
    This screen capture shows the Next and Exit buttons for
the Welcome installation screen.
    The Installer Questions screen appears.
  6. Decide if you want to reboot the system automatically and if you want to automatically eject the disc. Click Next.
    The Specify Media screen appears.
  7. Specify the media you are using to install. Click Next.
    The License panel appears.
  8. Accept the license agreement to continue the installation. Click Next.
    The Solaris installation program then determines if the system can be upgraded. To upgrade, the system must have an existing Solaris root (/) file system. The Solaris installation program detects the necessary conditions and then upgrades the system.
    The Select Upgrade or Initial Install screen appears.
  9. Decide if you want to perform an initial installation or an upgrade. Click Next.
    If you are upgrading a system that has non-global zones installed, follow these steps.
    1. When you are prompted to select initial installation or upgrade, choose Upgrade. Click Next.
    2. If your system has multiple root (/) partitions, select the partition that you want to upgrade on the Select Version to Upgrade panel.
      The Solaris installation program displays a message that indicates that you cannot customize your upgrade. The Solaris installation program analyzes your system to determine if the system can be upgraded. The Ready to Upgrade panel is displayed.
      If your system has only one root partition, the Solaris installation program does not prompt you to select a partition to upgrade. The partition is automatically selected.
    3. If you want to continue the upgrade, click Install Now on the Ready to Upgrade panel.
      The Solaris installation program begins to upgrade your system. After the upgrade is completed, you might need to correct some local modifications that were not preserved. For more information, go to Step a in Step 12.
      If you do not want to continue the upgrade, click Back to perform an initial installation.
  10. Select the type of installation you want to perform. Click Next.
    • Select Default Install to install the Entire Solaris Software Group.
    • Select Custom Install if you want to perform the following tasks.
      • Install a specific software group
      • Install additional software
      • Install specific software packages
      • Install a specific locale
      • Customize the disk layout
      For more information about software groups, see Disk Space Recommendations for Software Groups.
    Note –
    The text installer does not prompt you to select a Default or Custom Installation. To perform a default installation, accept the default values that are provided in the text installer. To perform a custom installation, edit the values in the text installer screens.
  11. If you are prompted, answer any additional configuration questions.
    When you have provided the information that is required to install the system, the Ready to Install screen is displayed.
    Figure 2–4 Solaris Installation Ready to Install Screen
    This screen capture shows the Ready to Install screen.
The screen lists the configuration information that was entered during the
installation.
  12. Click Install Now to install the Solaris software. Follow the instructions on the screen to install the Solaris software.
    When the Solaris installation program finishes installing the Solaris software, the system reboots automatically or prompts you to reboot manually.
    If you are installing additional products, you are prompted to insert the DVD or CD for those products. For installation procedures, refer to the appropriate installation documentation.
    After the installation is finished, installation logs are saved in a file. You can find the installation logs in the /var/sadm/system/logs and /var/sadm/install/logs directories.
    • If you are performing an initial installation, the installation is complete. Go to Step 13.
    • If you are upgrading the Solaris software, you might need to correct some local modifications that were not preserved. Continue to Step a.
      1. Review the contents of the /a/var/sadm/system/data/upgrade_cleanup file to determine whether you need to correct local modifications that the Solaris installation program could not preserve.
      2. Correct any local modifications that were not preserved.
  13. If you did not select automatic reboot during the installation, reboot the system.
    # reboot
Troubleshooting
If you encountered any problems during the installation or upgrade, see Appendix A, Troubleshooting (Tasks), in Solaris 10 6/06 Installation Guide: Custom JumpStart and Advanced Installations.
