Solaris 10 6/06 Installation Guide: Network-Based Installations
Procedurex86: To Create an x86 Install Server With SPARC or x86 DVD Media
Note –
This procedure assumes that the system is running the Volume Manager. If you are not using the Volume Manager to manage media, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without the Volume Manager.
Steps
  1. On the x86 system that is to become the install server, become superuser.
    The system must include a DVD-ROM drive and be part of the site's network and name service. If you use a name service, the system must also be in the NIS, NIS+, DNS, or LDAP name service. If you do not use a name service, you must distribute information about this system by following your site's policies.
  2. Insert the Solaris DVD into the system's drive.
  3. Create a directory to contain the boot image.
    # mkdir -p install_dir_path
    install_dir_path
    Specifies the directory where the DVD image is to be copied
  4. Change to the Tools directory on the mounted disc:
    # cd /cdrom/cdrom0/Solaris_10/Tools
    In the previous example, cdrom0 is the path to the drive that contains the Solaris OS DVD media.
  5. Copy the disc in the drive to the install server's hard disk by using the setup_install_server command:
    # ./setup_install_server install_dir_path
    install_dir_path
    Note –
    The setup_install_server command indicates whether you have enough disk space available for the Solaris Software disc images. To determine available disk space, use the df -kl command.
  6. Decide if you need to make the install server available for mounting.
    • If the install server is on the same subnet as the system to be installed or you are using DHCP, you do not need to create a boot server. Proceed to Step 7.
    • If the install server is not on the same subnet as the system to be installed and you are not using DHCP, complete the following steps.
      1. Verify that the path to the install server's image is shared appropriately.
        # share | grep install_dir_path
        install_dir_path
        Specifies the installation image where the DVD image was copied
        • If the path to the install server's directory is displayed and anon=0 is displayed in the options, proceed to Step 7.
        • If the path to the install server's directory is not displayed or you do not have anon=0 in the options, continue.
      2. Make the install server available to the boot server by adding this entry to the /etc/dfs/dfstab file.
        share -F nfs -o ro,anon=0 -d "install server directory" install_dir_path
      3. Verify that the nfsd daemon is running.
        • If the install server is running the Solaris 10 6/06 OS, or compatible version, type the following command.
          # svcs -l svc:/network/nfs/server:default
          If the nfsd daemon is online, continue to Step d. If the nfsd daemon is not online, start it.
          # svcadm enable svc:/network/nfs/server
        • If the install server is running the Solaris 9 OS, or compatible version, type the following command.
          # ps -ef | grep nfsd
          If the nfsd daemon is running, continue to Step d. If the nfsd daemon is not running, start it.
          # /etc/init.d/nfs.server start
      4. Share the install server.
        # shareall
  7. Change directories to root (/).
    # cd /
  8. Eject the Solaris DVD.
  9. (Optional) Patch the files that are located in the miniroot on the net install image that was created by setup_install_server.
    • For SPARC based installation images, use the patchadd -C command to patch the files that are located in the miniroot.
      # patchadd -C install_dir_path path-to-patch/patch-id
      install_dir_path
      Specifies the path to the network installation miniroot.
      path-to-patch
      Specifies the path to the patch that you want to add, for example, /var/sadm/spool.
      patch-id
      Specifies the patch ID that you want to apply.
      Caution – Caution –
      Don't use the patchadd -C command unless you have read the Patch README instructions or have contacted your local Sun support office.
    • For x86 based installation images, follow these steps to patch an x86 network installation miniroot.
      1. If the installation server is not running the Solaris 10 6/06 for x86 release, log in as superuser to another system on the network that is running the Solaris 10 6/06 for x86 release.
        To patch a Solaris 10 6/06 for x86 miniroot, your system must be running the Solaris 10 6/06 for x86 release.
        If your installation server is running the Solaris 10 6/06 for x86 release, go to Step d.
      2. Change to the Tools directory of the installation image you created in Step 5.
        # cd install-server-path/install-dir-path/Solaris_10/Tools
        install-server-path
        Specifies the path to the install server system on your network, for example, /net/installserver-1.
      3. Create a new installation image, and place that image on the system that is running the Solaris 10 6/06 for x86 release.
        # ./setup_install_server remote_install_dir_path
        Specifies the path on the Solaris 10 6/06 for x86 system in which to create the new installation image.
        This command creates a new installation image on the Solaris 10 6/06 for x86 system. In order to patch this image, you must temporarily place this image on a system that is running the Solaris 10 6/06 for x86 release.
      4. Unpack the network installation boot archive.
        # /boot/solaris/bin/root_archive unpackmedia install_dir_path \
          destination_dir
        install_dir_path
        Specifies the path to the x86 network installation image. If you created a new installation image in Step c, specify the path to the new image on the Solaris 10 6/06 for x86 system.
        destination_dir
        Specifies the path to the directory to contain the unpacked boot archive.
      5. Patch the unpacked boot archive.
        # patchadd -C destination_dir path-to-patch/patch-id
        path-to-patch
        patch-id
        You can specify multiple patches with the patchadd -M option. For more information, see patchadd(1M).
        Caution – Caution –
      6. Pack the x86 boot archive.
        # /boot/solaris/bin/root_archive packmedia destination_dir \
          install_dir_path
      7. If necessary, copy the patched miniroot to the installation image on the install server.
        If you patched the miniroot on a remote Solaris 10 6/06 for x86 system, you must copy the patched miniroot to the install server.
        # cp remote_install_dir_path/boot/x86.miniroot \
          install-server-path/install_dir_path/boot/x86.miniroot
  10. Decide if you need to create a boot server.
Example 8–3 x86: Creating an x86 Install Server With an x86 DVD
The following examples illustrate how to create an x86 install server by copying the Solaris Operating System for x86 Platforms DVD to the install server's /export/home/dvdx86 directory. This example assumes that the install server is running the Solaris 10 6/06 OS.
Set up the installation server.
# mkdir -p /export/home/dvdx86
# ./setup_install_server /export/home/dvdx86
Add the following path to the /etc/dfs/dfstab file:
share -F nfs -o ro,anon=0 -d "install server directory" /export/home/dvdx86
Check if the nfsd daemon is online. If the nfsd daemon is not online, start it and share it.
# shareall
# cd /
Example 8–4 Creating an x86 Install Server With a SPARC DVD
The following example illustrates how to create an x86 install server by copying the Solaris Operating System for SPARC Platforms DVD to the install server's /export/home/dvdsparc directory. This example assumes that the install server is running the Solaris 10 6/06 OS.
# mkdir -p /export/home/dvdscparc
# ./setup_install_server /export/home/dvdsparc
share -F nfs -o ro,anon=0 -d "install server directory" /export/home/dvdsparc
# shareall
# cd /
Continuing the Installation
After you set up the install server, you must add the client as an installation client. For information about how to add client systems to install over the network, see To Add Systems to Be Installed From the Network With add_install_client (DVD).
If you are not using DHCP, and your client system is on a different subnet than your install server, you must create a boot server. For more information, see Creating a Boot Server on a Subnet With a CD Image.
See Also
For additional information about the setup_install_server and the add_to_install_server commands, see install_scripts(1M).
