For x86 based systems, you can configure the following mouse information with the pointer keyword.
Pointing device
Number of buttons
IRQ level
Use the following syntax with the pointer keyword.
pointer=pointing_device {nbuttons=number_buttons irq=value} |
To set the value for the pointer keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the pointer keyword, and include this line in the sysidcfg file.
For more information, see the kdmconfig(1M)
