Create a master HMAC SHA1 key for the WAN boot server.
wanbootutil keygen -m
Create a HMAC SHA1 hashing key for the client.
wanbootutil keygen -c -o net=net-ip,cid=client-ID,type=sha1
Create an encryption key for the client.
net-ip is the IP address of the client's
subnet.
client-ID can be a user-defined ID or the
DHCP client ID.
key-type is either 3des or aes.
wanbootutil keygen -c -o net=net-ip,cid=client-ID,type=key-type
Split a PKCS#12 certificate file and insert the certificate in the client's truststore.
p12cert is the name of the PKCS#12 certificate
file.
subnet.
DHCP client ID.
wanbootutil p12split -i p12cert -t /etc/netboot/net-ip/client-ID/truststore
Split a PKCS#12 certificate file and insert the client certificate in the client's certstore
file.
subnet.
DHCP client ID.
keyfile is the name of the client's private
key.
wanbootutil p12split -i p12cert -c /etc/netboot/net-ip/client-ID/certstore -k keyfile
Insert the client private key from a split PKCS#12 file in the client's keystore.
key.
subnet.
client-ID can be a user-defined ID or a
DHCP client ID.
wanbootutil keymgmt -i -k keyfile -s /etc/netboot/net-ip/client-ID/keystore -o type=rsa
Display the value of a HMAC SHA1 hashing key.
wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=sha1
Display the value of an encryption key.
subnet.
DHCP client ID.
wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=key-type
Insert a hashing key or an encryption key on a running system. key-type can have a value of sha1, 3des, or aes.
/usr/lib/inet/wanboot/ickey -o type=key-type
