Solaris 10 6/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
(Optional) To Fall Back to the Source Boot Environment
The following procedures for falling back depend on your new boot environment activation situation:
Example 12–1 SPARC: To Fall Back Despite Successful Boot Environment Creation
In this example, the original c0t4d0s0 boot environment is reinstated as the active boot environment although it was activated successfully. The device name is first_disk.
# /sbin/luactivate first_disk
# init 6
Example 12–2 SPARC: To Fall Back From a Failed Boot Environment Activation
In this example, the new boot environment was not bootable. You must return to the OK prompt before booting from the original boot environment, c0t4d0s0, in single-user mode.
OK boot net -s
Do you want to fallback to activate boot environment c0t4d0s0
(yes or no)? yes
# init 6
The original boot environment, c0t4d0s0, becomes the active boot environment.
Example 12–3 SPARC: To Fall Back to the Original Boot Environment by Using a DVD, CD, or Net Installation Image
In this example, the new boot environment was not bootable. You cannot boot from the original boot environment and must use media or a net installation image. The device is /dev/dsk/c0t4d0s0. The original boot environment, c0t4d0s0, becomes the active boot environment.
OK boot net -s
# fsck /dev/dsk/c0t4d0s0
# mount /dev/dsk/c0t4d0s0 /mnt
# /mnt/sbin/luactivate
(yes or no)? yes
# umount /mnt
# init 6
Example 12–4 x86: To Fall Back to the Original Boot Environment By Using the GRUB Menu
Starting with the Solaris 10 1/06 release, the following example provides the steps to fall back by using the GRUB menu.
In this example, the GRUB menu is displayed correctly, but the new boot environment is not bootable. To enable a fallback, the original boot environment is booted in single-user mode.
  1. To display the GRUB menu, reboot the system.
    # init 6
    The GRUB menu is displayed.
    GNU GRUB version 0.95 (616K lower / 4127168K upper memory)
    |Solaris                                                            |
    |Solaris failsafe                                                   |
    |second_disk                                                        |
    |second_disk failsafe                                               |
    Use the ^ and v keys to select which entry is highlighted. Press
    enter to boot the selected OS, 'e' to edit the commands before
    booting, or 'c' for a command-line.
  2. From the GRUB menu, select the original boot environment. The boot environment must have been created with GRUB software. A boot environment that was created before the Solaris 10 1/06 release is not a GRUB boot environment. If you do not have a bootable GRUB boot environment, then skip to Example 12–5.
  3. Edit the GRUB menu by typing: e.
  4. Select kernel /boot/multiboot by using the arrow keys and type e. The grub edit menu is displayed.
    grub edit>kernel /boot/multiboot
  5. Boot to single user mode, by typing -s.
    grub edit>kernel /boot/multiboot -s
  6. Boot and mount the boot environment. Then activate it.
# b
(yes or no)? yes
# umount /mnt
# init 6
Example 12–5 x86: To Fall Back to the Original Boot Environment With the GRUB Menu by Using the DVD or CD
Starting with the Solaris 10 1/06 release, the following example provides the steps to fall back by using the DVD or CD.
In this example, the new boot environment was not bootable. Also, the GRUB menu does not display. To enable a fallback, the original boot environment is booted in single-user mode.
  1. Insert the Solaris Operating System for x86 Platforms DVD or Solaris Software for x86 Platforms - 1 CD.
  2. Boot from the DVD or CD.
    # init 6
    |Solaris                                                            |
    |Solaris failsafe                                                   |
  6. Boot and mount the boot environment. Then activate and reboot.
Select the original boot environment by using the arrow keys.
# b
(yes or no)? yes
# umount /mnt
# init 6
