Use the Status menu or the lustatus command to display the information about the boot environment. If no boot environment is specified, the status information for all boot environments on the system is displayed.
The following details for each boot environment are displayed:
Name – Name of each boot environment.
Complete – Indicates that no copy or create operations are in progress. Also, the boot environment can be booted. Any current activity or failure in a create or upgrade operation causes a boot environment to be incomplete. For example, if a copy operation is in process or scheduled for a boot environment, that boot environment is considered incomplete.
Active – Indicates if this is the active boot environment.
ActiveOnReboot – Indicates if the boot environment becomes active on next reboot of the system.
CopyStatus – Indicates if the creation or copy of the boot environment is scheduled, active, or in the process of being upgraded. A status of SCHEDULED prevents you from performing live upgrade copy, rename, or upgrade operations.
 To Display the Status of All Boot Environments
(Character User Interface)
(Character User Interface)From the main menu, select Status.
A table that is similar to the following is displayed:
| boot environment Is Active Active Can Copy Name Complete Now OnReboot Delete Status ------------------------------------------------------------------------ disk_a_S9 yes yes yes no - disk_b_S10database yes no no yes COPYING disk_b_S9a no no no yes - |
In this example, you could not perform copy, rename, or upgrade operations on disk_b_S9a because it is not complete, nor on disk_b_S10database, because a live upgrade operation is in progress.
(Command-Line Interface)
(Command-Line Interface)Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Type:
| # lustatus BE_name |
Specifies the name of the inactive boot environment to view status. If BE_name is omitted, lustatus displays status for all boot environments in the system.
In this example, the status for all boot environments is displayed.
| # lustatus boot environment Is Active Active Can Copy Name Complete Now OnReboot Delete Status ------------------------------------------------------------------------ disk_a_S9 yes yes yes no - disk_b_S10database yes no no yes COPYING disk_b_S9a no no no yes - |
You could not perform copy, rename, or upgrade operations on disk_b_S9a because it is not complete, nor on disk_b_S10database because a live upgrade operation is in progress.
