Insert the Solaris Operating System DVD or Solaris Software - 2 CD.
Run the installer for the media you are using.
If you are using the Solaris Operating System DVD, change directories to the installer and run the installer.
For SPARC based systems:
# cd /cdrom/cdrom0/s0/Solaris_10 6/06/Tools/Installers # ./liveupgrade20 |
For x86 based systems:
# cd /cdrom/cdrom0/Solaris_10 6/06/Tools/Installers # ./liveupgrade20 |
The Solaris installation program GUI is displayed.
If you are using the Solaris Software - 2 CD, run the installer.
% ./installer |
From the Select Type of Install panel, click Custom.
On the Locale Selection panel, click the language to be installed.
Choose the software to install.
For DVD, on the Component Selection panel, click Next to install the packages.
For CD, on the Product Selection panel, click Default Install for Solaris Live Upgrade and click on the other software choices to deselect them.
Follow the directions on the Solaris installation program panels to install the software.
