Solaris 10 6/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Upgrading a System With Packages or Patches
You can use Solaris Live Upgrade to add patches and packages to a system. Solaris Live Upgrade creates a copy of the currently running system. This new boot environment can be upgraded or you can add packages or patches. When you use Solaris Live Upgrade, the only downtime the system incurs is that of a reboot. You can add patches and packages to a new boot environment with the luupgrade command.
Caution – Caution –
When adding and removing packages or patches, Solaris Live Upgrade requires packages or patches that comply with the SVR4 advanced packaging guidelines. While Sun packages conform to these guidelines, Sun cannot guarantee the conformance of packages from third-party vendors. If a package violates these guidelines, the package can cause the package-addition software to fail or alter the active boot environment during an upgrade.
For more information about packaging requirements, see Appendix B, Additional SVR4 Packaging Requirements (Reference).
Table 9–2 Upgrading a Boot Environment With Packages and Patches
Type of Installation
Description
For More Information
Adding patches to a boot environment.
Create a new boot environment and use the luupgrade command with the -t option.
To Add Patches to an Operating System Image on a Boot Environment (Command-Line Interface)
Adding packages to a boot environment.
Use the luupgrade command with the -p option.
To Add Packages to an Operating System Image on a Boot Environment (Command-Line Interface)
