This section provides the procedure for using Solaris Live Upgrade to install Solaris Flash archives. Installing a Solaris Flash archive overwrites all files on the new boot environment except for shared files. Archives are stored on the following media:
HTTP server
FTP server – Use this path from the command line only
NFS server
Local file
Local tape
Local device, including DVD or CD
Note the following issues with installing and creating a Solaris Flash archive.
Description |
For More Information |
For examples of the correct syntax for paths that are associated with archive storage. | |
To use the Solaris Flash installation feature, you install a master system and create the Solaris Flash archive. |
For more information about creating an archive, see Chapter 3, Creating Solaris Flash Archives (Tasks), in Solaris 10 6/06 Installation Guide: Solaris Flash Archives (Creation and Installation). |
Install the Solaris Live Upgrade SUNWlur and SUNWluu packages on your system. These packages must be from the release you are upgrading to. For step-by-step procedures, see To Install Solaris Live Upgrade With the pkgadd Command.
From the Solaris Live Upgrade main menu, select Flash.
The Flash an Inactive Boot Environment menu is displayed.
Type the name of the boot environment where you want to install the Solaris Flash archive and the location of the installation media:
Name of Boot Environment: Solaris_10_606 Package media: /net/install-svr/export/Solaris_10_606/latest |
Press F1 to add an archive.
An Archive Selection submenu is displayed.
Location - Retrieval Method <No Archives added> - Select ADD to add archives |
This menu enables you to build a list of archives. To add or remove archives, proceed with the following steps.
To add an archive to the menu, press F1.
A Select Retrieval Method submenu is displayed.
HTTP NFS Local File Local Tape Local Device |
On the Select Retrieval Method menu, select the location of the Solaris Flash archive.
Media Selected |
Prompt |
HTTP |
Specify the URL and proxy information that is needed to access the Solaris Flash archive. |
NFS |
Specify the path to the network file system where the Solaris Flash archive is located. You can also specify the archive file name. |
Local file |
Specify the path to the local file system where the Solaris Flash archive is located. |
Local tape |
Specify the local tape device and the position on the tape where the Solaris Flash archive is located. |
Local device |
Specify the local device, the path to the Solaris Flash archive, and the type of file system on which the Solaris Flash archive is located. |
A Retrieval submenu is displayed, similar to the following example, which depends on the media you selected.
NFS Location: |
Type the path to the archive, as in the following example.
NFS Location: host:/path/to archive.flar |
Press F3 to add the archive to the list.
(Optional) To remove an archive from the menu, press F2.
When the list contains the archives that you want to install, press F6 to exit.
Press F3 to install one or more archives.
The Solaris Flash archive is installed on the boot environment. All files on the boot environment are overwritten, except for shareable files.
The boot environment is ready for activation. See To Activate a Boot Environment (Character User Interface).
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Type:
# luupgrade -f -n BE_name -s os_image_path -a archive |
Indicates to install an operating system from a Solaris Flash archive.
Specifies the name of the boot environment that is to be installed with an archive.
Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory.
Path to the Solaris Flash archive when the archive is available on the local file system. The operating system image versions that are specified with the -s option and the -a option must be identical.
In this example, an archive is installed on the second_disk boot environment. The archive is located on the local system. The operating system versions for the -s and -a options are both Solaris 10 6/06 releases. All files are overwritten on second_disk except shareable files. The pkgadd command adds the Solaris Live upgrade packages from the release you are upgrading to.
# pkgadd -d /server/packages SUNWlur SUNWluu # luupgrade -f -n second_disk \ -s /net/installmachine/export/Solaris_10_606/OS_image \ -a /net/server/archive/Solaris_10_606 |
The boot environment is ready to be activated.
This procedure provides the steps to install a Solaris Flash archive or differential archive by using a profile.
If you added locales to the profile, make sure that you have created a boot environment with additional disk space.
Create a profile.
See To Create a Profile to be Used by Solaris Live Upgrade for a list of keywords that can be used in a Solaris Live Upgrade profile.
Type:
# luupgrade -f -n BE_name -s os_image_path -j profile_path |
Specifies the name of the boot environment that is to be upgraded.
Path to a JumpStart profile that is configured for a flash installation. The profile must be in a directory on the local machine. The -s option's operating system version and the Solaris Flash archive operating system version must be identical.
In this example, a profile provides the location of the archive to be installed.
# profile keywords profile values # ---------------- ------------------- install_type flash_install archive_location nfs installserver:/export/solaris/flasharchive/solarisarchive
After creating the profile, you can run the luupgrade command and install the archive. The -j option is used to access the profile. The pkgadd command adds the Solaris Live Upgrade packages from the release you are upgrading to.
# pkgadd -d /server/packages SUNWlur SUNWluu # luupgrade -f -n second_disk \ -s /net/installmachine/export/solarisX/OS_image \ -j /var/tmp/profile |
The boot environment is then ready to be activated. To create a profile, see To Create a Profile to be Used by Solaris Live Upgrade.
This procedure enables you to install a Solaris Flash archive and use the archive_location keyword at the command line rather than from a profile file. You can quickly retrieve an archive without the use of a profile file.
Type:
# luupgrade -f -n BE_name -s os_image_path -J 'archive_location path-to-profile' |
Specifies to upgrade an operating system from a Solaris Flash archive.
Specifies the archive_location profile keyword and the path to the JumpStart profile. The -s option's operating system version and the Solaris Flash archive operating system version must be identical. For the keyword values, see archive_location Keyword in Solaris 10 6/06 Installation Guide: Custom JumpStart and Advanced Installations.
In this example, an archive is installed on the second_disk boot environment. The -J option and the archive_location keywords are used to retrieve the archive. All files are overwritten on second_disk except shareable files. The pkgadd command adds the Solaris Live Upgrade packages from the release you are upgrading to.
# pkgadd -d /server/packages SUNWlur SUNWluu # luupgrade -f -n second_disk \ -s /net/installmachine/export/solarisX/OS_image \ -J 'archive_location http://example.com/myflash.flar' |
