If the archive is stored on an FTP server, use the following syntax for the archive_location keyword.
archive_location ftp://user_name:password@server_name:port/path/filename optional_keywords |
The user name and password that you need to access the FTP server in the profile file.
The name of the server where you stored the archive.
A is an optional port. port can be a port number or the name of a TCP service that has a port number that is determined at runtime.
If you do not specify a port, the Solaris Flash installation utilities use the default FTP port number, 21.
The location of the archive to be retrieved from the specified server. If the path contains $HOST, the Solaris Flash installation utilities replace $HOST with the name of the clone system that you are installing.
The name of the Solaris Flash archive file.
The optional keywords that you can specify when you retrieve a Solaris Flash archive from an FTP server.
archive_location ftp://user1:secret@silver/archives/usrarchive.flar timeout 5
