This procedure assumes that the system is running Volume Manager. If you are not using Volume Manager to manage diskettes, CDs, and DVDs, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without Volume Manager.
Log in as superuser on a SPARC based system to which a diskette drive is attached.
Insert a blank diskette or a diskette that can be overwritten in the diskette drive.
# volcheck |
Determine if the diskette contains a UNIX file system (UFS).
Examine the contents of the file /etc/mnttab on the system for an entry such as the following:
/vol/dev/diskette0/scrap /floppy/scrap ufs suid,rw,largefiles,dev=1740008 927147040 |
If the entry exists, go to Step 6.
If the entry does not exist, go to the next step.
# newfs /vol/dev/aliases/floppy0 |
Determine if you want to copy examples of custom JumpStart files to your JumpStart directory.
If no, go to Step 9.
If yes, use the following decision table to determine what to do next.
Copy the example custom JumpStart files into the JumpStart directory on the profile diskette.
# cp -r media_path/Solaris_10_606/Misc/jumpstart_sample/* jumpstart_dir_path |
The path to the CD, DVD, or image on the local disk
The path to the profile diskette where you want to place the example custom JumpStart files
You must place all custom JumpStart installation files in the root (/) directory on the diskette.
For example, the following command copies the contents of jumpstart_sample on the Solaris Software for SPARC Platforms - 1 CD to the root (/) directory on a profile diskette that is named scrap:
cp -r /cdrom/sol_10_606_sparc/s0/Solaris_10_606/Misc/jumpstart_sample/* /floppy/scrap |
Update the example JumpStart files on the profile diskette so that the files work in your environment.
Ensure that root owns the JumpStart directory and that permissions are set to 755.
Eject the diskette.
# eject floppy |
You have completed the creation of a profile diskette. You can now update the rules file and create profiles on the profile diskette to perform custom JumpStart installations. To continue, go to Creating the rules File.
