Required Options
-n archive_name
The value of this flag is the name of the archive. The archive_name you specify is the value of the content_name keyword.
Option for Compression
-c
Compresses the archive by using compress(1).
Options for Directories and Sizes
-R root
Creates the archive from the file system tree that is rooted at root. If you do not specify this option, flarcreate creates
an archive from a file system that is rooted at /.
-S
Omits sizing information in the archive.
-H
Does not generate the hash identifier.
Options for Creating a Differential Archive
-A unchanged_master_image_dir
Creates a differential archive by comparing a new system image with
the image that is specified by the unchanged_master_image_dir argument.
By default, the new system image is root (/). You can
change the default with the -R option. unchanged_master_image_dir is a directory where the unchanged master system image is stored
or mounted through UFS, NFS, or lumount.
You can modify the effects of file selection for a differential archive
by using the options for contents selection described in the next section
of the table.
-M
Excludes the manifest file. When you use this option, no validation
occurs on the differential archive. When creating a differential archive, flarcreate creates
a long list of the files in the system that are unchanged, are changed, and
are to be deleted from the archive. This list is stored in the manifest section
of the archive. When the differential archive is deployed, the software uses
this list to perform a file-by-file check, ensuring the integrity of the clone
system. Use of this option avoids such a check and saves the space that is
used by the manifest section in a differential archive. However, you must
consider the savings in time and disk space against the loss of an integrity
check upon installation. Because no validation occurs, avoid using this option.
Options for Contents Selection
Caution – Use the flarcreate file-exclusion options
with caution. If you exclude some directories, others that you were unaware
of might be left in the archive, such as system configuration files. The system
would then be inconsistent and the installation would not work. Excluding
directories and files is best used with data that can easily be removed without
disrupting the system, such as large data files.
-y include_dir/filename
Adds to the archive those files and directories that are specified on
the command line. This option is used when you have excluded a directory,
but want to restore individual subdirectories or files.
include_dir/filename is the name of the subdirectory
or file to be included.
-f list_filename
Adds files and directories from a list to the archive.
list_filename is the full path to a file
that contains a list. The contents of the file are added to the file list
unless -F is specified.
The list_filename file must contain
one file per line.
If you specify a file system with -R root, the path to each file must be relative to the alternate root directory or an absolute path.
If filename is “-”, flarcreate reads
standard input as the list of files. When you use the value “-”,
the archive size is not calculated.
-F
Uses only the files in -f list_filename to
create the archive. This option makes the -f list_filename the absolute list, rather than a list that is appended to the
normal file list.
-x exclude_dir/filename
Excludes files and directories from the archive. These files and directories
are specified at the command line. You can use multiple instances of this
option to exclude more than one file or directory.
exclude_dir/filename is the name of the directory
or file to be excluded.
-X list_filename
Excludes a list of files or directories from the archive.
that contains the list.
one file per line.
If list_filename is “-”, flarcreate reads
-z list_filename
Excludes or includes a list of files or directories from the archive.
Each file or directory in the list is noted with a plus “+” or
minus “-”. A plus indicates an included file or directory and
the minus indicates an excluded file or directory.
one file per line.
-I
Override the integrity check. To prevent you from excluding important
system files from an archive, flarcreate runs an integrity
check. This check examines all files that are registered in a system package
database and stops archive creation if any of them are excluded. Use of this
option overrides this integrity check. Therefore, avoid the use of the -I option.
Options
for Splitting and Merging Archives
-d dir
Retrieves the sections to copy from dir,
rather than from the current directory.
-u section
If you use this option, flar copies the
cookie, identification, archive, and section sections. You
can specify a single section name or a space-separated list of section names.
If you do not use this option, flar copies the cookie, ldentification, and archive sections only.
-f archive
Extracts the archive section into a directory that is named archive, rather than placing it in a file with the name archive. Used for splitting an archive
-S section
Only copies the section that is named section from
the archive. This section is user defined. Used for splitting an archive.
Options Used With User-Defined Sections
-u section
Includes section as a user-defined section.
To include more than one user-defined section, section must
be a space-separated list of section names.
-d dir
Retrieves the section file that is specified with -u from dir.
Options Used With Tape Archives
-t
Creates an archive on a tape device. The filename argument
is the name of the tape device.
-p posn
Use only with the -t option. Specifies the position
on the tape device for flarcreate to store the archive.
If you do not use this option, flarcreate places the archive
at the current position of the tape.
-b blocksize
Specifies the block size flarcreate uses when creating
the archive. If you do not specify a block size, flarcreate uses
the default block size of 64 KB.
Options for Archive Identification
These keywords and values appear in the archive identification section of the archive.
-U key=val
Includes user-defined keywords and values in the archive identification section.
-i date
Uses date as the value for the creation_date keyword. If you do not specify a date, flarcreate uses
the current system time and date.
-m master
Uses master as the name of the master system
on which you created the archive. master is the
value for the creation_master keyword. If you do not
specify master, flarcreate uses
the system name that is reported by uname -n.
-e descr
Uses descr for the value of the content_description keyword. You cannot use this option when you use the -E option.
-E descr_file
Retrieves the value for the content_description keyword
from the descr_file file. You cannot use this
option when you use the -e option.
-a author
Uses author as the author name in the archive identification section. author is the value for the content_author keyword.
If you do not specify an author, flarcreate does not include the content_author keyword in the archive identification section.
-T type
Uses type as the value for the content_type keyword. type is user defined. If you
do not specify a type, flarcreate does not include the content_type keyword.
