Solaris 10 11/06 Installation Guide: Network-Based Installations
Configure the WAN Boot Server to Use HTTPS
To use HTTPS in your WAN boot installation, you must enable SSL support in the web server software. You must also install a digital certificate on the WAN boot server. This example assumes that the Apache web server on wanserver-1 is configured to use SSL. This example also assumes that a digital certificate and a certificate authority that establish the identity of wanserver-1 are already installed on wanserver-1.
For examples about how to configure your web server software to use SSL, see you web server documentation.
