Solaris 10 11/06 Installation Guide: Network-Based Installations
ProcedureTo Install a Hashing Key and an Encryption Key on a Running Client
You can set key values at the wanboot program boot> prompt on a running system. If you use this method to install keys, the keys are only used for the current WAN boot installation.
If you want to install a hashing key and an encryption key in the OBP of a running client, follow these steps.
Before You Begin
This procedure makes the following assumptions.
  1. Assume the same user role as the web server user on the WAN boot server.
  2. Display the key value for the client keys.
    # wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=key-type
    net-ip
    The IP address of the client's subnet.
    client-ID
    The ID of the client you want to install. The client ID can be a user-defined ID or the DHCP client ID.
    key-type
    The key type you want to install on the client. Valid key types are 3des, aes, or sha1.
    The hexadecimal value for the key is displayed.
  3. Repeat the previous step for each type of client key you want to install.
  4. Become superuser or assume an equivalent role on the client machine.
  5. Install the necessary keys on the running client machine.
    # /usr/lib/inet/wanboot/ickey -o type=key-type
    > key-value
    key-type
    Specifies the key type you want to install on the client. Valid key types are 3des, aes, or sha1.
    key-value
    Specifies the hexadecimal string that is displayed in Step 2.
  6. Repeat the previous step for each type of client key you want to install.
    After you install the keys, you are ready to install the client. See Installing the Client for instructions about how to install the client system.
Example 12–3 Installing Keys in the OBP of a Running Client System
The following example shows how to install keys in the OBP of a running client.
Display the key values on the WAN boot server.
# wanbootutil keygen -d -c -o net=192.168.198.0,cid=010003BA152A42,type=sha1
b482aaab82cb8d5631e16d51478c90079cc1d463
# wanbootutil keygen -d -c -o net=192.168.198.0,cid=010003BA152A42,type=3des
9ebc7a57f240e97c9b9401e9d3ae9b292943d3c143d07f04
The previous example uses the following information.
net=192.168.198.0
Specifies the IP address of the client's subnet
cid=010003BA152A42
Specifies the client's ID
Specifies the value of the client's HMAC SHA1 hashing key
Specifies the value of the client's 3DES encryption key
If you use an AES encryption key in your installation, change type=3des to type=aes to display the encryption key value.
Install the keys in the OBP of the running client.
# /usr/lib/inet/wanboot/ickey -o type=sha1 b482aaab82cb8d5631e16d51478c90079cc1d463
# /usr/lib/inet/wanboot/ickey -o type=3des 9ebc7a57f240e97c9b9401e9d3ae9b292943d3c143d07f04
The previous commands perform the following tasks.
Continuing the WAN Boot Installation
After you install keys on your client, you are ready to install the client over the WAN. For instructions, see Installing the Client.
See Also
For more information about how to display key values, see the man page wanbootutil(1M).
For additional information about how to install keys on a running system, see ickey(1M).
