Solaris 10 11/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Displaying the Name of the Active Boot Environment
Use the Current menu or the lucurr command to display the name of the currently running boot environment. If no boot environments are configured on the system, the message “No Boot Environments are defined” is displayed. Note that lucurr reports only the name of the current boot environment, not the boot environment that is active on the next reboot. See Displaying the Status of All Boot Environments to determine a boot environment's status.
ProcedureTo Display the Name of the Active Boot Environment (Character User Interface)
    From the main menu, select Current.
    The active boot environment's name or the message “No Boot Environments are defined” is displayed.
ProcedureTo Display the Name of the Active Boot Environment (Command-Line Interface)
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # /usr/sbin/lucurr
Example 7–4 Displaying the Name of the Active Boot Environment (Command-Line Interface)
In this example, the name of the current boot environment is displayed.
# /usr/sbin/lucurr
solaris8
