Solaris 10 11/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Using Solaris Live Upgrade Menus (CUI)
Figure 4–1 Solaris Live Upgrade Main Menu
The screen capture shows Solaris Live Upgrade tasks and
the Enter and Help keys.
Navigation through the menus of the Solaris Live Upgrade character user interface requires that you use arrow keys and function keys. Use arrow keys to navigate up and down before making a selection or to place the cursor in a field. To perform a task, use the function keys. At the bottom of the menu, you see black rectangles that represent function keys on the keyboard. For example, the first black rectangle represents F1 and the second black rectangle represents F2. Rectangles that are active contain a word that represents a task, such as Save. The Configuration menu notes the function key number plus the task, rather than a rectangle.
In the following procedures, you might be asked to press a function key. If your function keys do not properly map to the function keys on the Solaris Live Upgrade menus, use Control-F plus the appropriate number.
