Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
Creating a custom_probes File
The rule and probe keywords that are described in Rule Keywords and Values and Probe Keywords and Values might not be precise enough for your needs. You can define your own custom rule or probe keywords by creating a custom_probes file.
The custom_probes file is a Bourne shell script that contains two types of functions. You must save the custom_probes file in the same JumpStart directory where you saved the rules file. The two types of functions that you can define in a custom_probes file are as follows:
Syntax of the custom_probes File
The custom_probes file can contain any valid Bourne shell command, variable, or algorithm.
Note –
You can define probe and comparison functions that require a single argument in the custom_probes file. When you use the corresponding custom probe keyword in the rules file, the argument after the keyword is interpreted (as $1).
When you use the corresponding custom rule keyword in the rules file, the arguments are interpreted in sequence. The sequence starts after the keyword and ends before the next && or begin script, whichever comes first.
The custom_probes file must meet the following requirements:
To improve clarity and organization, define all probe functions first, at the top of the file, followed by all comparison functions.
Syntax of Function Names in custom_probes
The name of a probe function must begin with probe_. The name of a comparison function must begin with cmp_.
Functions that begin with probe_ define new probe keywords. For example, the function probe_tcx defines the new probe keyword tcx. Functions that begin with cmp_ define new rule keywords. For example, cmp_tcx defines the new rule keyword tcx.
ProcedureTo Create a custom_probes File
  1. Use a text editor to create a Bourne shell script text file. Name the file custom_probes.
  2. In the custom_probes text file, define your probe and comparison functions.
    Note –
    You can define probe and comparison functions that require arguments in the custom_probes file. When you use the corresponding custom probe keyword in the rules file, the arguments after the keyword are interpreted in sequence (as $1, $2, and so on).
  3. Save the custom_probes file in the JumpStart directory next to the rules file.
  4. Ensure that root owns the rules file and that the permissions are set to 644.
Examples of a custom_probes File and Keyword
You can find additional examples of probe and comparison functions in the following directories:
The following custom_probes file contains a probe and comparison function that tests for the presence of a TCX graphics card.
Example 5–1 custom_probes File
#!/bin/sh
# custom_probe script to test for the presence of a TCX graphics card.
# PROBE FUNCTIONS
probe_tcx() {
  SI_TCX=`modinfo | grep tcx | nawk '{print $6}'`
  export SI_TCX
# COMPARISON FUNCTIONS
cmp_tcx() {
  probe_tcx
  if [ "X${SI_TCX}" = "X${1}" ]; then
     return 0
  else
     return 1
  if
The following example rules file shows the use of the probe keyword that is defined in the preceding example, tcx. If a TCX graphics card is installed and found in a system, profile_tcx is run. Otherwise, profile is run.
Note –
Always place probe keywords at or near the beginning of the rules file. This placement ensures that the keywords are read and run before other rule keywords that might rely on the probe keywords.
Example 5–2 Custom Probe Keyword Used in a rules File
probe tcx
tcx     tcx     -     profile_tcx     -
any     any     -     profile         -
