Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
ProcedureTo Allow All Systems Access to the Profile Server
Use the following procedure only if you store network installation information in the following places:
If you use the following procedure, the systems must be of the same type, such as all SPARC systems.
Do not use this procedure under the following conditions:
If you have the above conditions, use the SPARC boot command or use the x86 GRUB menu.
Note –
You also can store network installation information on a DHCP server.
  1. On the installation or boot server, log in as superuser.
  2. Use a text editor to open /etc/bootparams.
  3. Add this entry.
    * install_config=server:jumpstart_dir_path
    A wildcard character that specifies that all systems have access
    server
    The host name of the profile server where the JumpStart directory is located
    jumpstart_dir_path
    The absolute path of the JumpStart directory
    For example, the following entry enables all systems to access the /jumpstart directory on the profile server that is named sherlock:
    * install_config=sherlock:/jumpstart
    Caution – Caution –
    Use of this procedure might produce the following error message when an installation client is booted:
    WARNING: getfile: RPC failed: error 5: (RPC Timed out).
    Booting From the Network, Error Messages contains details about this error message.
    All systems can now access the profile server.
