Solaris 10 11/06 Installation Guide: Solaris Flash Archives (Creation and Installation)
Creating Archives for SPARC and x86 Systems
If you want to install Solaris software by using a Solaris Flash archive on both SPARC and x86 systems, you must create a separate Solaris Flash archive for each platform. Use the Solaris Flash archive that was created from the SPARC master system to install SPARC systems. Use the Solaris Flash archive that was created from the x86 master system to install x86 systems.
