Solaris 10 11/06 Installation Guide: Solaris Flash Archives (Creation and Installation)
Task Map: Creating Solaris Flash Archives
Table 3–1 Task Map: Creating a Solaris Flash Archive to Install With an Initial Installation
Task
Description
For Instructions
Install your chosen software configuration on the master system
Determine the configuration that meets your needs and use any of the Solaris installation methods to install the master system.
To Install the Master System for an Initial Installation
(Optional) Create customization scripts
Determine if you need to create scripts to do the following:
  • Customize or reconfigure the archive
  • Protect local changes on clone systems
Creating Customization Scripts
Create the Solaris Flash archive
Use the flarcreate command to create an archive.
To Create a Solaris Flash Archive for an Initial Installation
(Optional) Save a copy of the archive
Keep a copy of the archive for future comparison to update a clone system with a differential archive.
Table 3–2 Task Map: Creating a Solaris Flash Archive to Update a Clone System
Task
Description
For Instructions
Prepare master image
Make changes to the unchanged master image such as adding or deleting packages or installing patches.
Installing the Master System
Create the Solaris Flash differential archive
  1. Mount the unchanged master image.
  2. Use the flarcreate command to compare the two images and create the differential archive.
To Create a Solaris Flash Differential Archive With an Updated Master Image
