Solaris 10 11/06 Installation Guide: Solaris Flash Archives (Creation and Installation)
Creating a Solaris Flash Archive and Customizing Files (Examples)
Example 3–10 Creating an Archive and Excluding and Including Files and Directories
In this example, the archive is named archive2. This archive is copied from the master system but is not an exact copy. The content under the /aaa directory is excluded, but the content in /aaa/bbb/ccc remains.
# flarcreate -n archive2 -x /aaa -y /aaa/bbb/ccc  archive2.flar
To check the file structure of the archive, type the following. The excluded directories that include copied files appear, but only the files that were restored contain data.
# flar info -l aaa
aaa
aaa/bbb/ccc
aaa/bbb/ccc/ddd
aaa/bbb
ggg
Example 3–11 Creating an Archive Excluding and Including Files and Directories by Using Lists
In this example, the archive is named archive5. This archive is copied from the master system but is not an exact copy.
The exclude file contains the following list:
/aaa
The include file contains the following list:
/aaa/bbb/ccc
# flarcreate -n archive5 -X exclude -f include  archive5.flar
To check about the file structure of the archive, type the following. The excluded directories that include copied files appear, but only the files that were restored contain data.
# flar info -l archive5.flar
aaa
aaa/bbb/ccc
aaa/bbb/ccc/ddd
aaa/bbb
ggg
Example 3–12 Creating an Archive Excluding Files and Directories by Using a List and Restoring a Directory
You can combine options -x, -y, -X and -f. In this example, options -X and -y are combined. The archive is named archive5. This archive is copied from the master system but is not an exact copy.
/aaa
The -y option restores the /aaa/bbb/ccc directory. The following command produces the archive.
# flarcreate -n archive5 -X exclude -y /aaa/bbb/ccc  archive5.flar
aaa
aaa/bbb
aaa/bbb/ccc
aaa/bbb/ccc/ddd
ggg
Example 3–13 Creating an Archive Excluding and Including Files and Directories by Using a List With the -z Option
In this example, the archive is named archive3. It is copied from the master system but is not an exact copy. The files and directories to be selected are included in filter1 file. Within the files, the directories are marked with a minus (-) or a plus (+) to indicate which files to exclude and restore. In this example, the directory /aaa is excluded with a minus and the subdirectory /aaa/bbb/ccc is restored with a plus. The filter1 file contains the following list.
- /aaa
+ /aaa/bbb/ccc
# flarcreate -n archive3 -z filter1 archive3.flar
To check the file structure of the archive, type the following command. The excluded directories that include copied files appear, but only the files that were restored contain data.
# flar info -l archive3.flar
aaa
aaa/bbb
aaa/bbb/ccc
aaa/bbb/ccc/ddd
ggg
