The following figure shows a RAID-1 volume that duplicates the root file system (/) over two physical disks. State database replicas (metadbs) are placed on both disks.
Figure 8–2 shows a system with the following configuration.
The mirror that is named d30 consists of the submirrors that are named d31 and d32. The mirror, d30, duplicates the data in the root (/) file system on both submirrors.
The root (/) file system on hdisk0 is included in the single-slice concatenation that is named d31.
The root (/) file system is copied to the hard disk named hdisk1. This copy is the single-slice concatenation that is named d32.
State database replicas are created on both slices: hdisk0 and hdisk1.
Description |
For More Information |
JumpStart profile example |
Profile Examples in Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations |
Solaris Live Upgrade step-by-step procedures |
