使用此过程将当前处于运行级别 0 的系统引导至运行级别 3。
ok boot |
自动引导过程会显示一系列的启动消息,并使系统进入运行级别 3。有关更多信息,请参见 boot(1M) 手册页。
确认系统已引导至运行级别 3。
引导过程成功完成后,将显示登录提示。
hostname console login: |
以下示例显示了将系统引导至运行级别 3 时出现的消息。
ok boot Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz) OpenBoot 3.15, 128 MB memory installed, Serial #number. Ethernet address number, Host ID: number. Rebooting with command: boot Boot device: /pci@1f,0/pci@1,1/ide@3/disk@0,0:a File and args: kernel/sparcv9/unix SunOS Release 5.10 Version s10_60 64-bit Copyright 1983-2004 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. configuring IPv4 interfaces: hme0. add net default: gateway 172.20.27.248 Hostname: starlite The system is coming up. Please wait. NIS domain name is example.com starting rpc services: rpcbind keyserv ypbind done. Setting netmask of hme0 to 255.255.255.0 Setting default IPv4 interface for multicast: add net 224.0/4: gateway starlite syslog service starting.The system is ready. Starting Sun(TM) Web Console Version 2.1-dev.. volume management starting. The system is ready. starlite console login: |
在前面的示例中,sparcv9 仅为一个示例。此字符串与 isainfo -k 命令的输出匹配。
