系统管理指南:基本管理
x86: Device Configuration Assistant 屏幕
注 –
在此 Oracle Solaris 发行版中,Device Configuration Assistant 屏幕已被基于 x86 的系统上的 GRUB 菜单取代。有关更多信息,请参见使用 GRUB 引导基于 x86 的系统(任务图)。
在 Solaris 10 初始发行版中,自动引导过程会跳过 Device Configuration Assistant 菜单,除非您在引导阶段看到系统提示时按了 Esc 键。如果选择使用 Device Configuration Assistant,则会显示以下屏幕。
Solaris Device Configuration Assistant
The Solaris(TM)Device Configuration Assistant
scans to identify system hardware, lists identified devices, and can
boot the Solaris software from a specified device. This program must be
used to install the Solaris operating environment, add a driver,
or change the hardware on the system.
> To perform a full scan to identify all system hardware, choose Continue.
> To diagnose possible full scan failures, choose Specific Scan.
> To add new or updated device drivers, choose Add Driver.
About navigation...
	- The mouse cannot be used.
	- If the keyboard does not have function keys or they do not respond,
	  press ESC. The legend at the bottom of the screen will change to
	  show the ESC keys to use for navigation.
	- The F2 key performs the default action.
F2_Continue		F3_Specific Scan		F4_Add Driver		F6_Help
