当 Device Configuration Assistant 尝试识别系统中的设备时,将显示多个屏幕。
本节提供了以下引导子系统屏幕的示例:
Device Configuration Assistant 屏幕
“总线枚举”屏幕
“扫描设备”屏幕
“已识别设备”屏幕
在此 Oracle Solaris 发行版中,Device Configuration Assistant 屏幕已被基于 x86 的系统上的 GRUB 菜单取代。有关更多信息,请参见使用 GRUB 引导基于 x86 的系统(任务图)。
在 Solaris 10 初始发行版中,自动引导过程会跳过 Device Configuration Assistant 菜单,除非您在引导阶段看到系统提示时按了 Esc 键。如果选择使用 Device Configuration Assistant,则会显示以下屏幕。
| Solaris Device Configuration Assistant
The Solaris(TM)Device Configuration Assistant
scans to identify system hardware, lists identified devices, and can
boot the Solaris software from a specified device. This program must be
used to install the Solaris operating environment, add a driver,
or change the hardware on the system.
> To perform a full scan to identify all system hardware, choose Continue.
> To diagnose possible full scan failures, choose Specific Scan.
> To add new or updated device drivers, choose Add Driver.
About navigation...
	- The mouse cannot be used.
	- If the keyboard does not have function keys or they do not respond,
	  press ESC. The legend at the bottom of the screen will change to
	  show the ESC keys to use for navigation.
	- The F2 key performs the default action.
F2_Continue		F3_Specific Scan		F4_Add Driver		F6_Help |
当 Device Configuration Assistant 针对可自动检测的设备收集硬件配置数据时,会短时间出现“总线枚举”屏幕。
| Bus Enumeration Determining bus types and gathering hardware configuration data ... Please wait ... |
当 Device Configuration Assistant 手动扫描仅能使用特殊驱动程序检测的设备时,将出现“扫描设备”屏幕。
| Scanning Devices The system is being scanned to identify system hardware. If the scanning stalls, press the system's reset button. When the system reboots, choose Specific Scan or Help. Scanning: Floppy disk controller ####################### | | | | | | 0 20 40 60 80 100 Please wait ... |
“已识别设备”屏幕显示在系统上已识别的设备。从该屏幕可以继续访问“引导 Solaris”菜单。
或者,可以执行以下可选的设备任务:
设置键盘配置
查看并编辑设备
设置串行控制台
保存并删除配置
| Identified Devices The following devices have been identified on this system. To identify devices not on this list or to modify device characteristics, such as keyboard configuration, choose Device Tasks. Platform types may be included in this list. ISA: Floppy disk controller ISA: Motherboard ISA: PnP bios: 16550-compatible serial controller ISA: PnP bios: 16550-compatible serial controller ISA: PnP bios: Mouse controller ISA: PnP bios: Parallel port ISA: System keyboard (US-English) PCI: Bus Mastering IDE controller PCI: Universal Serial Bus PCI: VGA compatible display adapter F2_Continue F3_Back F4_Device Tasks F6_Help |
